Exporting Spline as a DXF
Hi! I am having trouble exporting Splines in DXF Format, When i try to do this it exports the pull bars which adjust its curvature, and not the spline itself.
Is there some way to export a dxf directly from a surface like in solidworks?
HughesTooling
Just did a test using Rhino, what I noticed was I only got spline handles on points I'd edited apart from that the spline opened fine. The problem with the spline handles was reported a long time ago guess it never go fixed!Smiley Sad
Mark
Mark Hughes
Owner, Hughes Tooling
(Just realized i posted in a different profile, Having other issues that have forced me to create two to access my designs :/, and i usually forget which one i'm in before posting )
This is what i'm getting:
DXF:
Actual FIle:
It has also done some weird stuff in the lower left corner of this design, exporting a feature that isn't even in the sketch: (see the deformed slot)
Opening in A360 Viewer gives this, Splines are there now but it is missing other features
HughesTooling
Don't know what you need the splines for but there is a plugin that convert spline to plines.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=4611814297957846949&appLang=en&os=Win64
Mark
Mark Hughes
Thanks for the link! ill check it out!
In that case the lines ended up being relatively straight, but that was not my initial intention, so that is why i was using a spline,
Still confused as to why some segments of the sketch are not showing in A360 Viewer, while they do in a different DXF Viewer and why segments of the DXF do not match the shapes displayed in the sketch.
