Exporting multiple components to a new file
dwoodville
dwoodville
I'm working on a chassis for rock crawling and have used bendtech to build the main chassis tubes, exported and then imported it into fusion. Fusion is just to complicated to build the chassis in, that's a whole other topic though. I have multiple parts/components that I've brought into the file in order to design the suspension parts, steering etc. etc. Unfortunately there are multiple edits I must do to the chassis during this process which means making the changes in bendtech and re-importing it info fusion. What I'm trying to prevent is importing multiple chassis versions into my working file every time I make an edit because ultimately I can't delete the previous chassis I've been designing around. There are so many components linked to it and this would undoubtedly cause a bunch of issues. So I'm thinking if I can save the motor, axles, suspension pieces and a few mounts into a new file that would help in my process. However, I'd like to maintain the current dimensional relationship that the motor, axles and all other components (minus the chassis) currently have. This way I can import a new chassis and "plop" it into place and check things out to see how I like it. I just tried uploading but my file size is 111mb. Any where else I can upload for folks to see?
TheCADWhisperer
@dwoodville wrote:
I'm working on a chassis…
@dwoodville
Are you on personal license or are you on commercial license?
If on commercial license then just provide a link.
What is the file size of the chassis before import into Fusion?
What file type?
Can you Attach example of only the chassis?
dwoodville
I'm on a personal, educational license at the moment. The bendtech file is only 1.6mb. I attached the bendtech export of the chassis only as requested.
