Message 1 of 12
		04:17 AM
    - Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I export a sketch locally as a DXF file, I can open it with RDworks for lasercutting. However, in RDworks the splines are not exactly as they are in Fusion360 and a few straight lines are added. If I import that same DXF in Rhino3D, Rhino3D is warning that there are errors in the model and If I then continue to open that DXF, I get the same kind of errors as I see in RDworks. What is causing this problem and what can I do to fix it? As attachments I added three screenshots from the original sketch in Fusion360 and in RDworks and in Rhino3D.
