Exporting deformed results of FEA simulation
mmilleratticus
mmilleratticus
In this post there is a discusion about exporting results to other softwares for further analysis:
https://forums.autodesk.com/t5/fusion-360-design-validate/exporting-simulation-mesh-and-results-from...
                                                              ~Also~
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I'm interested in exporting the deformed prediction for 3D printing and or overlay against the original model.  Is this possible?
mmilleratticus
So, I've installed and downloaded Paraview:
                    https://www.paraview.org/
Very  software.  Plenty of "How To" videos on the web.  However I have not been able to view anything other than the first step of an event simulation.
Has anyone had any luck viewing all the steps of an event simulation in Paraview?  OR even the last step?
Thanks!
John_Holtz
Autodesk Support
Autodesk Support
Hi @mmilleratticus
The export command only exports the current step that you are viewing, so it will definitely not output all of the results.
If you view the last step and create the output, what results does Paraview show?
[edit 1. To clarify my original post, the VTU output gives the undeformed mesh (the nodes, coordinates, elements) and the current result that is being viewed -- stress, total displacements, whatever result is chosen in the pull-down selector.]
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
mmilleratticus
Hi John,
I'm using whatever the latest version of Fusion 360 is available.
mmilleratticus
John,
Screenshot of the imported results in Paraview.  For some reason the filter "Warp by Vector" is grey.  I'm guessing that is critical to an accurate deformation.  I'm wondering if the data out from Fusion isn't in a format that Paraview sees the vector??
Seems like a lot of work to get at something that is essentially available in Fusion and a useful tool.
John_Holtz
Autodesk Support
Autodesk Support
After seeing your post, I realized that my initial reply was incomplete. I just updated it. Essentially, the undeformed mesh (nodes, elements, coordinates) and the result that is currently displayed is written to the VTU file. In your case, the von Mises stress is written. Since the VTU file does not contain any information about the displacement, Paraview would not be able to show a real deformed shape. (My guess is the deformation that is shown is based on the stress magnitude in the file.)
Yes, Fusion has limited capabilities by design.
John Holtz, P.E.
Autodesk, Inc.
