Export Sketch as PDF or DXF with Dimensions Unchanged
tranq006
tranq006
This may be out of the scope of these forums, but all I am trying to do is essentially get a sketch exported somehow to a PDF such that I can open it on Adobe Acrobat Reader and print it as multiple sheets to tape together to be full size (poster or tile print). However, currently I am exporting the sketch as a DXF and then converting online to PDF, but every time I do this the actual dimensions get changed. Does anyone know of a way to actually achieve what I'm trying to do? I've attached the DXF in imperial units for reference. Thanks
jhackney1972
Your DXF did not make it to your post.
John Hackney, Retired
tranq006
It doesn't seem to let me attach it. I've attached the part file instead, there is a sketch labeled "DXF" that you can export as DXF if you're able. Thanks
ClintBrown3D
Hi @tranq006
Have you considered creating a 2D drawing at a scale of 1:1 and export this to PDF?
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
tranq006
Thanks, that worked for this! I wonder if there is another way to do it if, for instance, your sketch was larger than the maximum sheet size
