Export point coordinates?
joergen_nilsson
joergen_nilsson
Is it somehow possible to export the point (or corner) coordinates from a sketch?
The purpose is to using the coordinates in a separate program for calculating 2D trusses.
jhackney1972
There is no real point export routine in Fusion but they do have "Copy to Clipboard" on the Measure command.  If you are using Windows operating system, you can activate the Extended Clipboard and then it is an easy job to record and then paste coordinates to another application.  The video will show this.
John Hackney, Retired
joergen_nilsson
Thanks, but I run on Mac. However, I found a script on modthemachine.typepad.com but can't get it to work properly.
import traceback, adsk.core, adsk.fusion
import io
def run(context😞
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
# Get all components in the active design.
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
title = 'Export Spline csv'
if not design:
ui.messageBox('No active Fusion design', title)
return
# if app.userInterface.activeSelections.count != 1:
# ui.messageBox('Select profile before running command', title)
# return
# profile = app.userInterface.activeSelections.item(0).entity
# if not type(profile) is adsk.fusion.Profile:
# ui.messageBox('Selected object needs to be a profile', title)
# return
dlg = ui.createFileDialog()
dlg.title = 'Save CSV File'
dlg.filter = 'Comma Separated Values (*.csv)'
if dlg.showSave() != adsk.core.DialogResults.DialogOK :
return
filename = dlg.filename
with io.open(filename, 'w', encoding='utf-8-sig') as f:
profile = adsk.fusion.Profile.cast(profile)
loop = profile.profileLoops.item(0)
curves = loop.profileCurves
for curve in curves:
curve = adsk.fusion.ProfileCurve.cast(curve)
entity = curve.sketchEntity
point = entity.startSketchPoint
point = adsk.fusion.SketchPoint.cast(point)
geometry = point.geometry
f.write(str(geometry.x) + "," + str(geometry.y) + "\\n")
except:
if ui:
ui.messageBox('Failed:\\n\{\}'.format(traceback.format_exc()))
johnsonshiue
Hi! I am not sure if the "Publish to PLY" app on Fusion App store would help.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=8481236243625457783&appLang=en&os=Win64
Please take a look.
Many thanks!
Software Test Engineer
joergen_nilsson
Looks promising but only on Windows.
