Message 1 of 53
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When exporting a fusion drawing as DXF if i send that drawing to be laser cut they cannot use the file.
If they open it in draft sight only half of the drawing is visible if they open it in Autocad it it has problems too.
The only way i have found to correct the problem is get a trial version of Autocad and use the export layout command to make the drawing readable.
Then it can be opened in other programs a lot of people we use for laser cutting use draft sight because of the free version.
Is there any chance this can be fixed soon as i cannot have another trial of Autocad and would prefer to use one program.
Kind Regards Mark
