Export - assembly parts as single files?
cheryl_sneddon
cheryl_sneddon
Hi All,
I understand that I can export an assembly out as a step from Fusion 360 and I can export out individual files out as single step files....
BUT
Can I export the assembly with all components as single step files together as one command?
End user needs to have single steps for each part as they use Solidworks
Any help would be appreciated 🙂
g-andresen
NO
günther
Phil.E
Have you tried any of the other export types? Export the assembly as Inventor. This produces assembly and part files. Your downstream application should be happy with that.
Or SAT export which produces a single file with all components as bodies. Inventor can convert multi body files into assemblies pretty easily, perhaps your downstream application can as well.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
