Exclude sub-components from derive
ltomuta
Advisor Advisor
ltomuta
I think this used to be possible, even if the source of the derive is a configuration. And then, it stopped working.
Bug or feature?
I want to derive this design but exclude some components, selected out in the dialog. But when I finish the derive, the entire design is imported, including the undesired components.
HughesTooling
Seems to work for me.
Just select the component you don't want and the X should become selectable. This works for bodies, sketches etc.
In your image the component doesn't look like it's selected, it's not highlighted.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Sorry didn't read carefully enough. I can confirm what you are seeing with a derive from a design with configurations. Excluding items works fine with ordinary designs but in a design with configurations all items are transferred to the derived design even if unselected.
@Phil.E  Is this a known limitation?
Mark Hughes
Phil.E
I'm not sure, so I've asked for help from the configurations team.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
gautham_kattethota
@ltomuta
This is a miss from our side.  We have logged a defect for this and we will be addressing this soon.  Thanks for reporting it.
Regards
Gautham
Gautham Kattethota
Software Development
