Error: STIFFNESS MATRIX SINGULAR OR NON-POSITIVE DEFINITE
04:07 AM
I need help.
A very simple simulation gives me this error.
I can't find how to solve this to get a good solution.
Cause : A singularity or non-positive definite has been detected in the stiffness matrix during the
preconditioning phase of the iterative solver.
Action : Investigate the model for a lack of constraint. If using shell elements, either set the
K6ROT model parameter to a value between 1.0 and 100.0, or set the SHELLRNODE model
parameter to ON. Also, check for elements with bending stiffness (line and shell
elements) improperly connected to elements without (solids). If you are unable to
locate the source of the singularity, consider using the sparse direct solver.
