Error: Selection not found in cached body or sketch.
trace_public
Message 1 of 12
trace_public
Okasionaly seeng this error, when working in master assembly and syncing assembly contexts across external components. The tool body just disappears from assembly context, therefore it does exist in it's file. Adding the lost body to Context also doesn't work. It appears in context tree but when I press ok, no error is shown but nothing happens. Body just doesn't appears in context's bodies list. I tried to restart fusion, restart computer, wipe out the cache (W.Login folder in App Support) and then reload master assembly with all children components but nothing helps. Also there is no circular context depends between contexts in related components. What could be the problem?
Replies (11)
Message 2 of 12
mango.freund
hello, sometimes it is simply the case that the timline did not dock at the end and the calculation was therefore not completed. just play until the end and - voila. best regards mango
Message 3 of 12
trace_public
Thank you for an answer, of course, I checked this at first. As you can see on the attached video, in the beginning of it, the timeline is also at it's end. No matter how many times I go back and forth, nothing changes. Error is still there.
Message 4 of 12
mango.freund
Hello, I stick to my opinion, because I could see exactly where your pointer was in the timeline. but the least is that you pull your pointer forward and let it work through step by step so that it can be calculated. you should do the direct processing of this assembly alone without the other ballast.
I see such errors in myself when I remove parts that will be used later. to find out step by step. it is always advisable to bring the timepointer to the current situation. mango
Message 5 of 12
trace_public
I also just did check other operation with the needed tool body, lost from assembly context. I also can't project this body to a sketch, not only perform boolean operations. It gives the same error. I suppose, it don't depends on operations I do try to perform, but on the assembly context error itself. But the body do exist in parent file I trying to take it from.
Message 6 of 12
trace_public
Sorry, I know, that you really want to help, but look at attached image...
And I repeat, I tried to go over timeline forth and back several times... I also tried to edit this particular feature with marker just at this feature, there is no difference.
Message 7 of 12
mango.freund
Message 8 of 12
trace_public
I just don't get it, you really don't believe me?.. ))
I attached another video of what you telling me. I tried this several times in addition to what I mentioned in the starting answer. Just look the attachment
Message 9 of 12
mango.freund
take the risk and delete the red elements.
if it still locks - then go back again
I only recommend writing to the admins directly. I'm really sorry.
Message 10 of 12
trace_public
I tried what you say before, it didn't work. For sure, it's an assembly context problem, neither timeline nor operations. I tried now to make another context, not using that one, with the same bodies and it worked. It seems, that I found a bug. Hope, the admins will look here and say something. It's a bad idea of creating million of contexts in assembly in every case like that
Message 11 of 12
fusion1E9EX5
Hi did you figure it out by any chance? working in assemblies and had the same issue
Message 12 of 12
leuteris_kant
Community Visitor
Community Visitor
Guys what worked for me was to open the part and edit the context that contains the a corelation with the missing feature (tool feature) and use it as i wanted.
