Error finder zooms backward in sketch of Fusion 360.
Message 1 of 1
I noticed that when we are "debugging" a drawing's parameters and/or constraints, when we click on a parameter error message the error message finder zoom to the appropriate parameter, however if we do the same thing with a constraint error message the finder instead of zooming toward the "defective" constraint it zooms out witch seems to be the opposite of what it should be doing.
consequently I have to look for the slightly greenish constraint on a large sketch with several hundreds of constraints then zoom in to remove or modify the constraint causing problems and wasting precious time in the process. Can this be fixed in one way or other?
thank you.
Replies (0)
