Error. Combine - Cut bodies.
2 REPLIES 2
fundamental4
394 Views, 2 Replies
fundamental4
I need help, please. I don't know what's wrong here.
How can I Combine-Cut (Body 22 - Body 31)?
File:
http://a360.co/2EF5gmR
File:
2 REPLIES 2
jeff_strater
in reply to: fundamental4
jeff_strater
the problem here is that some faces of these two bodies are coincident.  If you have coincident faces that are not just simple planes or cylinders, Combine is going to have a hard time succeeding.  One way around this is to move one of the bodies so that there is a more clear overlap, if your design constraints will allow that.  I found by moving just 0.005mm, I can get Combine to work:
Jeff
Jeff Strater
Engineering Director
Jeff
Jeff Strater
fundamental4
in reply to: jeff_strater
fundamental4
Hello Jeff,
thank you for your quick reply.
I did as you said, I had to move it 0.5 mm in order to be cut, but I obtained a weird base for new body.
Body 22 is a support for body 31 to 3d printed, so it has fairly freedom to be designed, as long as it was small, and its base must be smaller (or iqual) than 0.4 mm. because it will be "hinged broken" at this point.
In principle it can only be modified with this Sketch19 +Sweep (Body23) to be Cutted.
So, my goal is a Body 31 with a base 0.4mm (+-0.1).
Hello Jeff,
