I have included a picture of my project. I have a student whos father was in the military and he wanted to make him a simple trailer hitch cover of a Claymore Mine.
We want to 3d print it and sand cast it then weld a 2x2 tube to it. So far we have it drawn with all the taper/draft angles needed to pull from the sand, and the first print releases from the sand perfectly except the text. It tears out the text as I can't figure out a way to add taper/draft angle to the text. I used the emboss tool to make the text curved on the surface (blue area is the curved surface) but there is no taper/draft angle in that tool. Any other way to do this? Any way to project the text onto curved surface then I can just use extrude with a 3 degree taper/draft angle?
