Elongate a portion of an existing stl
Message 1 of 9
Hi All,
Newbie here.  TIA for you patience and help.
I downloaded an stl (see attached) and would like to modify it.  I converted to BRep.  I would like to "stretch" it where I have drawn the line, so that area is longer.  If I scale in y, everything with stretch and I don't want that.
Thank you so much for your help.
Replies (8)
Message 2 of 9
TrippyLighting
Use Autodesk Meshmixer for such things
Message 3 of 9
Thanks!  I downloaded and tried.  Edit transform scale, but it still stretches the entire piece, making the holes elliptical.  I'm trying to just make the bracket longer, without modifying the ends.
Message 4 of 9
TheCADWhisperer
Frankly on something that simple I would remodel from scratch, but since you asked - Split Body, Move Body and then build and combine the new section.
Message 5 of 9
"That simple":)
Thank you for your help.
Please see attached.
Message 6 of 9
So I split, moved, extruded, and joined.  I think that worked, thank you.  Not sure how to build a body.
Message 7 of 9
TheCADWhisperer
Did Extrude not in fact “build a body”?
Message 8 of 9
Yes!  Just wasn’t sure if you were referring to something else. Thank you so much for your help. Greatly appreciated
Message 9 of 9
TheCADWhisperer
I would have use precise terms like Extrude rather than "build" in my initial response if you had Attached your file in the original post, but I couldn't tell from the screen capture if there was taper to the geometry or something else that I could not see that would complicate the "build" process.
In any case, sounds like you figured it out.
Always best to post your actual geometry.
