Drawing with features removed.
tld23
Message 1 of 8
tld23
Sorry if this is a obvious question but I'm still finding my way around F360. I am trying to produce a drawing. I want two similar views on the drawing. One view has all features showing and the second similar view shows the same part with some features removed so I can improve readability by removing clutter. I can only seem to get both views with all features or both views with the features removed as the drawings update from the Design package. Any ideas how I can achieve what I want?
Many thanks in advance
Terry
Replies (7)
Message 2 of 8
g-andresen
create an independent copy of the component (paste new) and hide the corresponding features there.
günther
Message 3 of 8
tld23
Thanks for the tip, I can see that will work. I was hoping for a more elegant solution as I am hoping to reuse the Design and Drawings in the future and if I or others don't update the extra part it may all go wrong (although I could re dimension the extra part with cross reference to the original part dimension references). All a bit messy, but should work.
Message 4 of 8
TheCADWhisperer
Message 5 of 8
tld23
Sorry I can't upload the file as it is a confidential project.
Terry
Message 6 of 8
HughesTooling
Edit think I might have misunder stood, this is a single body not an assembly?
You can create a second Base View in the drawing then hide components or bodies you don't need under the second base view in the browser.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 8
tld23
Tried this, I was hopeful at first but two problems. 1) my component is a sheet metal part and I want to draw a flat pattern and 2) I can remove all of the parts that I don't need but I cannot drill down to the feature level within a part. Thanks any way.
Terry
Message 8 of 8
TheCADWhisperer
Terry
In that case, can you make up a dummy file that exhibits the same behavior and Attach it here?
