- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working with a part that has multiple instances. The part is a sub-plate that will be used for multiple manufacturing setups/orientations. Basically I'm grounding a model and pasting new instances of the sub plate around the model in different orientations. By doing this I can make sure none of my locating/fastener holes from one orientation conflict with another orientation. Hope that makes some sense...
The issue I'm having is I need to edit a sketch in orientation (instance) #7. When I activate this instance and edit the sketch, Fusion is changing the active component to the first instance. This changes the orientation of the sub-plate and I can no longer project geometry from my model onto instance #7. This is a proprietary file that I can't share but I did make a screen cast to illustrate my issue.
How do I edit this sketch and keep instance #7 as the active component? Please feel free to ask for more info if needed. Thanks in advance for your input.
Link to screencast (until I can get it uploaded to the thread): https://autode.sk/2N4a25K
