Editing features
Editing features
Message 1 of 27
Editing features
Hello!
I might have a really simple problem, but...
How can I edit a feature after applying it? For example, if I want to modify the depth of a cut/extrusion in Model view, how can I do that?
Since Fusion 360 is out of the Beta phase that should be pretty easy.
Thank you for the help!
Replies (26)
Message 21 of 27
OMG this had been bugging the crap out of me for a LONG time. I remember having history mode but now all I use are imported models I thought they turned that ability off for some reason.. Not very intuitive.
Message 22 of 27
I decided to make a reply to this post because there are still may be some people looking for this answer, even if it is an older question. The link to the post labeled "Answer" is blocked for some reason...so, if anyone is still looking for the  answer and does not want to (or cannot) click on the link, this answer is for you.
If you select the drop-down menu from the modify section of the tool ribbon there will be a "Change Parameters" option near the bottom. If you click on this it will bring up a separate screen with all of the actions that have been taken so far... similar to the tool tip while hovering over the option. You can make any changes in this screen.
It should be noted, however, that when you click on one of the items the whole project may highlight. In this case you will just need to use trial and error to find the correct surface that you want to change.
I hope this helps.
Message 23 of 27
laughingcreek
That it probably the most difficult way possible to go about making changes to your model.  And wouldn't answer the original question since it originated back before fusion was parametric.
Message 24 of 27
maximeURGVK
Hi, i tried your solution but there is no extrusion values to be changed.
As a user, i know its not the best to complain, but in the meanwhile i would like that some of the forum answers to be more honest and less focus on hiding reality. Witch, in this current problem, my only option is to delete everything and start all over again. (i also lost the time i spent trying to find a solution).
Message 25 of 27
g-andresen
Please start a new thread and post a current problem, if possible with images (screenshots or screencast) and a sample file.
günther
Message 26 of 27
laughingcreek
did you try editing the feature?
Message 27 of 27
maximeURGVK
sorry i cant reply i have to start a new threat
