Edit parameters for overlapping objects in a sketch?
jflegert
jflegert
I'm editing a sketch.  I have to circular patterns.  I want to edit one, but can't select and edit it as the pattern icons overlap.  I normally double click, but since they over lap, I can't get to the one I want.
I click and hold and select one of the patterns, it gets highlighted, but I don't know how to edit it.
Thank you for the help
g-andresen
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
jflegert
Please see the attached file with the two circular patterns.
TheCADWhisperer
Long left click to get the Select Other, but you might consider Feature Pattern rather than sketch pattern.
jflegert
Selecting it isn't the problem.  When I long left click it, it selects it, but how do I edit it once it has been selected?
g-andresen
even if it is not comfortable, it works:
günther
jflegert
Thank you.
