第 1 条消息(共 8 条)
Edit Joint from Browser is confusing
I am building an assembly and often need to edit a joint. When I right-click on the joint in the browser and select Edit Joint, the Joint Dialog box comes up but it doesn't reflect the parameters I set in the original joint.
For example, I'm trying to edit a Revolute joint, but the edit dialog shows a Planar joint. Huh??? What I would expect to happen is for the dialog to come up with the exact parameters I set when I created the joint so that I could actually edit them. Ideally, the dialog would be filled exactly as it was before I clicked OK.
Is this a bug, a feature or am I doing something wrong?
