Removing Fillets from Imported Geometry
I have a fairly complex model that I imported from a STEP file.  It came in as a solid, and I have a complex edge that has a fillet I need to remove (replacing it simply with a "square" edge).
I am able to simplly Delete Face on some of the fillet faces and it automagically heals.  But, I seem to be unable to go any further as it can't figure out how to heal when I try to delete any of the remaining faces.
Any thoughts on another way to quickly square up an edge that is rounded?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'd be glad to take a look at this file and try to give some suggestions. Do you mind sharing the file with me via email at james.youmatz@autodesk.com. I'll let you know as soon as I make some headway and have an answer for you!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Email sent, thanks James.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm taking a look at the file and I'm curious as to what fillet you are referring to exactly. Do you think you could post a quick screencast showing what you are trying to do? You can download screencast at the following link, www.screencast.autodesk.com.
As soon as I see what you are trying to do, I will take a peek and see if I can fix it!
James Youmatz
