I am starting with Fusion 360 and i have really stucked at the Coil tool. I try to make a coil with a custom profile which is a isosceles triangle with base length 0.75 mm and height 0.75 mm. I made a sketch of this triangle but I can't use it as profile to my coil as it is done in Autodesk Inventor. The only thing I can do is to set Section to 'Trangular (Internal)' and Section Size to desired height, but it creates only equilateral triangle. Furthermore I can't choose plane when coil begins - the Coil toll seems to choose XY plane as beginning.
So the best option would be to choose sketched profile and all problems would be solved, but is it possible? If not, what to do?
I would be very grateful for your help š
