Coil with custom profile
Message 1 of 11
I am starting with Fusion 360 and i have really stucked at the Coil tool. I try to make a coil with a custom profile which is a isosceles triangle with base length 0.75 mm and height 0.75 mm. I made a sketch of this triangle but I can't use it as profile to my coil as it is done in Autodesk Inventor. The only thing I can do is to set Section to 'Trangular (Internal)' and Section Size to desired height, but it creates only equilateral triangle. Furthermore I can't choose plane when coil begins - the Coil toll seems to choose XY plane as beginning.
So the best option would be to choose sketched profile and all problems would be solved, but is it possible? If not, what to do?
I would be very grateful for your help 😃
Replies (10)
Message 2 of 11
TannerReid
Hi, apawelek92,
The coil tool today is an automated tool that generates a spiral and sweeps a pre-set profile along that path, so it's not possible to use a custom profile within the tool. While you could draw a 3-d sketch and sweep, I think I've found an easier way to do this that still utilizes the coil tool.  It's a 3-step process, rather than one, but it took me about 2mins. Screencast here:
<iframe width="640" height="400" src="https://screencast.autodesk.com/Embed/95f2e0d0-df33-4364-9fc9-844efe51de7b" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Basically, you're insetting a triangle pointed out for the coil - that way, the tip of that triangle is always along the spiral path generated to the specifications you choose in the tool.  Then, you can create a custom profile, and sweep around that solid edge created by the triangular coil.  Just remember to make it a solid body, rather than a cut!  šŸ™‚
Did that help?  Sorry the tool doesn't do exactly what you need it to do, but hopefully, this work-around isn't too painful for you.
What else can we do to help with your project?
Enjoy yourself,
Tanner
Tanner Reid
Product Design Engineer
Message 3 of 11
TannerReid
Sorry - embedded incorrectly!  Here's the screencast link:  http://autode.sk/1Igu9xv
Tanner Reid
Message 4 of 11
It is very clever idea, thank you very much for help and the movie šŸ™‚ unfortunately the profile rotates when sweep is used, you can see it on your movie. For this reason I decided to use Coil tool  for my design and set equilateral triangle, but if you or someone else will find solution it would be great šŸ™‚
Message 5 of 11
michallach81
For now try to follow this screencast: http://autode.sk/1Q9129B  (most important copy desired profile every half of turn)
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 6 of 11
This one seems promising šŸ™‚  However I am not able to get my geometry working šŸ˜• Primarily I don't know kow to properly make 3d helical curve - sketch tools seem not to do what I expect. I can't include 3d projected edge nor edges of coil, as on the movie the last step is including helical curve in Loft tool. So if I know how to do that it is huge chance that it finally will work
Message 7 of 11
michallach81
Only easy way is to create Coil with triangle profile (important use section: triangular external and for section position: inside.) and then create sketch and include external edge.
Take a look on screencast: http://autode.sk/1NWjugq
Michał Lach
Designer
co-author
Message 8 of 11
Thank you for help michallach81! Finally I did it! Cat Happy
One more thing that I had to do was to use 21 Lofts instead of 1 (1 loft every 180 deg), because my pitch was equal to height of the profile so the edges intersected. It is crazy how many operations are rquired to do coil with custom profile. Inventor has this simple feature, why Fusion 360 doesn't? Autodesk should definitely consider it.
Message 9 of 11
cekuhnen
@Anonymous You could also use this approach:
https://drive.google.com/a/ckbrd.de/file/d/0Byzv_NlyKp_2cG9rLVVZbDZlTHc/view?usp=drivesdk
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 10 of 11
amoldshelke
Guys, it is very easy, but first, is here anybody can create this type of spring.....
I have a solution to this also.
And Please suggest me how can I show my tricks and tips of fusion 360.
I have lots of tricks which are better than this.
front view of rectangular spring.pngtop view of rectangular spring.pngrectangular spring.pngrectangular spring error.PNGspring excersice.jpg
Message 11 of 11
bur0023
Community Visitor
Community Visitor
I just used 3d sketch and incrementally translated corners of my sketch downwards to get the desired coil.
Worked ok
