I’m working on a sketch at the moment where I’ve joined two parallel lines with a spline using the “Blend Curves” tool. However, I want to reduce the tangency weight at each end while keeping both weights equal still, so I have that same symmetry still but have a shallower curve.
As far as I can find, the only way to edit the spline curvature is with the handles, but that lacks the precision I’m looking for. Is there a more precise tool? Or am I stuck having to eyeball it?
If there’s a workaround for this specific use case I’m open to that too, but this is not the first time I’ve run into this problem so a general solution would be appreciated.
Can’t attach screenshots right now but I will when I get home.
