Edit Face command on a solid deletes object
nathanslocum
Message 1 of 8
nathanslocum
Hello, this is my first post. I have been reading some of the forums and they have been super helpful. I recently ran into a problem that I'm not sure how to overcome. I have a intake tube that I want to make a dent in because it contacts the front fender. I'm attempting to use the modify > edit face command, but when I do it, instead of doing what the preview shows, it deletes the material. I haven't worked with T-splines before as I haven't needed a complex curved surface. This is my first time working with this type of modeling.
Replies (7)
Message 2 of 8
TheCADWhisperer
You have numerous Bodies and 3 Components.
Which body are you attempting to edit?
Is there a logical reason that you do not have Capture Design History active?
Is something like this what you are attempting to achieve?
Message 3 of 8
nathanslocum
Thank you for the quick reply. That's exactly what I'm trying to do! I grouped a couple of components together for this one bike, I didn't expect to post it asking for help so the file is a little disorganized. I disactivated design history because several guides I saw using the edit face feature said that had to be done. I wouldn't have done it otherwise. How did you do that? Sorry if this is a very basic function, I have been fiddling with it for two hours and couldn't seem to make it work myself.
Message 4 of 8
TheCADWhisperer
I turned on the Record History - so my steps are recorded in the Timeline for you to examine.
Message 5 of 8
TrippyLighting
Is there a reason you are working with the timeline disabled?
Message 6 of 8
TheCADWhisperer
See response #3 - bad advice from some “unnamed source”.
Message 7 of 8
nathanslocum
Thanks for that file showing me how to do it. I am a total amateur at this and wouldn't have thought to use those commands. I usually stick to sketching and extruding with some fillets. As far as turning the design history off, it was because of these two guides: Fusion 360 help guide and Fusion 360 Forum .
I thought T splines would be my best bet, but I didn't (still don't) know enough about it to work it right.
Message 8 of 8
nathanslocum
Just wanted to throw an update to the project. This is a 1960's Honda C100 that I engine swapped and needed a custom intake for. It's not perfect and I'll likely redesign, but it actually fits with your all's help.image_50420737.JPG
