I'm trying to create a parameterised GT2 pulley wheel, which takes a tooth count parameter and resizes the wheel accordingly.
I have what seems like a weird issue - The general process i'm doing is
- create 1 end piece
- create the other end piece
- create a tooth
- do a circular pattern to create all the other teeth
- create the core of the wheel, by doing an extrude with "join" set to connect all the bodies into 1
This works fine once. But if I change the tooth count parameter, the model creates the teeth correctly, but the "new" teeth are separate bodies, rather than joining to the main body.
It's not the biggest issue, but i wonder if someone can explain, or come up with a way around it.
