Edit a Split
Edit a Split
alvbogatyrev
Edit a Split
alvbogatyrev
Community Visitor
Community Visitor
I am trying to move a split a couple of millimeters up the body, but when I do that I get a bunch of cannot compute errors. Is there any way to move up the split without having to redo everything? Please help and thank you!
dsouzasujay
Hi @alvbogatyrev,
Can you attach prior designs that you have already completed in Fusion 360?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
davebYYPCU
Looks like you are using the Move Tool, (not recommended)
Edit the article location used as the cutter.
Blue sketch line, (not recommended,) can be click dragged,  or
Offset Plane,  Edit the Feature.
Might help....
