Easy selection of elements that are overlaid
SimonPlatten
Message 1 of 18
SimonPlatten
I often have sketches where I have a dash line then on top of this a solid line, for example the dashed line runs from:
100,500 (x,y) to 200,500
Then on top of this a solid line runs from:
50,500 to 100,500
I can see both lines in the sketch, but selecting the top solid line is very difficult and almost always the dash line gets selected, is there some way of doing this that I do not know?
Replies (17)
Message 2 of 18
rushabhthakkar_910
I tried it. And did not face any issue.
Can you share your model or a screencast video..?
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 3 of 18
SimonPlatten
How do I do that?  I'm using iMAC.
Message 4 of 18
rushabhthakkar_910
Have a look at THIS for exporting the File..!!
Have a look at THIS for Screencast..!!
(If not screencast, you can record the video from other software too and share the video here..)
Thanks and Regards,
Rushabh Thakkar.
Message 5 of 18
SimonPlatten
I cannot show that the two printed models do not mate in a screencast, that requires both models to be printed and a video created then uploaded, I don't have the resources to do this.
Message 6 of 18
rushabhthakkar_910
No issues, you can share your model than..!!
Thanks and Regards,
Rushabh Thakkar.
Message 7 of 18
SimonPlatten
Sorry I was getting mixed up between two threads....its very simple, as I said originally, open Fusion 360, draw a line, press x to make it dashed, then draw another line along it exactly on top of it.
The question is how do you select one or the other because on the version I have:
Fusion 360, version 2.0.13162
macOS 12.4 x84_64 (21F69) on iMac17,1
This isn't easy at least I don't know how to do it.
Message 8 of 18
rushabhthakkar_910
Have a look at this Screencast Video..!!
(https://autode.sk/3MYkxS1)
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 18
SimonPlatten
When I tried to view the video:
Message 10 of 18
rushabhthakkar_910
No issues.. Attaching the MP4 file..
Thanks and Regards,
Rushabh Thakkar.
Message 11 of 18
stiller.design
I agree its indeed not easy and most of the time the underlying sketch gets selected but not the active sketch. I usually hide then the other sketch and then its works better. BUT ITS ANNOYING INDEED
Message 12 of 18
SimonPlatten
But what if the elements are in the same sketch as mine are?
I guess the best solution would be to put them on separate sketches ?
Message 13 of 18
stiller.design
try to long press your left mouse button, then you can select the sketch line in the dialog.
that should work
Message 14 of 18
g-andresen
leftclick+hold is your friend
günther
Message 15 of 18
SimonPlatten
How do you get the selection box up?
Message 16 of 18
SimonPlatten
Thank you, that's sorted now.
Message 17 of 18
stiller.design
well this is exactly what I said...anyway nvm
Message 18 of 18
stiller.design
yeap
