(easy) Maintain wall thickness when extruding pipe geometry
Untitled.pngI would like to taper this object while maintaining its wall thickness. Recommendations?
This is so elementary, thank you for the time & space.
jeff_strater
do this in two steps:  Extrude the pipe as solid, with taper, then add a Shell feature to make it hollow.  Extrude with taper of the hollow profile will not produce uniform wall thickness
Jeff Strater
Engineering Director
g-andresen
1. Extrude outside D with taper
2. "Shell"  with wall thickness
günther
jhackney1972
A little more involved.  Extrude inside and outside diameters as tapered surfaces.  Then patch each end and stitch all together.
John Hackney, Retired
jeff_strater
screencast:
Jeff Strater
Thanks, I knew extruding a shell wouldn't work.
This is workable advice.
Something you can do in Blender is make a curve and some shape to extrude along it (along with yet another curve to determine diameter over its length), could I do similar in Fusion?
Thanks. Just trying to learn so I can play with my 3D printer and make cool kinetic art.
