Easiest way to Knurl a flat surface?
harrison.friedes
harrison.friedes
I have a flat surface I'd like to apply a knurl to in order to stick better to the wall with heavy duty tape. Any idea the best way to do this? Right now I'm multiplying 50 lines across a ~50mm circle both vertically and horizontally and extruding every other one (selecting them manually), which believe it or not is pretty inconvenient and ineffective.
Fusion file attached below as well, thank you in advance : )
Warmingup1953
Mmmm is that a proven way to increase tape adhesion?
3D Print? Resin?
No attachment
harrison.friedes
Good questions, thanks. I haven't tested it out to yet but I hope it will improve adhesion, and this will be 3d-printed.
Warmingup1953
Attachment?
g-andresen
1. create a sketch with just one profile (centered) and  extrude/taper (cut or join) it
2. create a rectangular pattern > feature extrude (select from timeline) > define directions > spacing >  symmetrical > option: identical
günther
TrippyLighting
3D Print? Resin?
No attachment
Nope, it accomplishes exactly the opposite!
