Hi Mr Lynn.Sim, Fellows,
I will try to explain the phenomenon you are facing. Still, please take into account that I am an outsider and do not have insight into what the Fusion Team is doing under the blanket of development activities.
The assessment below is based on my past experiences and telepathic tracing.
Now, let’s go to the matter at hand.
Generally, the typography process of assembling script from individual glyphs (characters) takes into account different customs and methods of doing so across many planetary languages; which is pretty complex. TF360 recognized it relatively recently, delivering the new sketchText object.
The previous one was quite basic and could not address the ‘diversity’ of typography methods.
Re-inventing a new typography wheel would border with … (add your own adjective here); thus, they adopted what is available via the OS GDI software layer.
In the case of scripting, GDI covers diverse typographical methods of assembling glyphs but also enhances them through so-called ‘localization’, adding to the mix of local writing customs. In our case of Hebrew, it is the direction of scripting. In Latin World, a sequence of bytes “ABCD” appears on the paper as “ABCD” … however, in Hebrew will be pictured as “DCBA”. A similar situation might happen in traditional Japanese, where glyphs are placed vertically, and in many other locales/languages.
There are other ‘subtle’ issues like kerning, ligatures, … of fine-tuning final scripts, which from time to time pop-ups on the Forum … but it is too vast subject to cover.
Thus, go to our Hebrew problem.
I guess, … the problem you are facing … would disappear if the F360 software is installed and run on Hebrew localization (or such is activated). OS then would correctly assemble the script, reversing characters beforehand.
Is there another at-hock solution? Yes, you can do it our self,
Perhaps there is also a more structural method of addressing it.
Ask TF360 to add a button to sketch Text dialogue (on the side of flipping ones), reversing the order of characters in the input text.
Regards
MichaelT
P.S.
Having a button for vertical (like traditional Japanese) scripts would also be … welcome.
MichaelT
