- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to place this text on a circular path. In the text dialog text window it appears exactly as it should. But on the path each individual character is backwards. I am using the Frank CurledLamed font, with the Windows Hebrew keyboard enabled. The characters are entered using the Windows onscreen keyboard.
I also tried using the spline tool to create a curve. Exactly the same results. The horizontal and vertical flip options just make the problem worse.
שמע ישראל יהוה אלהינו יהוה אחר ואחבת את יחוח אלחיך בכל לבבך ובכל נפשך ובכל מאדך
Am I missing something, or is this a bug? Any suggestions would be greatly appreciated.
This is the spline attempt:
This is the circular attempt:
Thank you.
I just tried using a regular rectangular text box. The text appeared exactly as it should. So it appears that the text on path option is where the problem is.
