DXF Import - Millions of Points
charlie.buscher
charlie.buscher
When I import a dxf into fusion360 I am seeing the dxf except that its covered by millions of points.
I should add that I've imported the same dxf file to other programs such as solidedge without issue.
I tried selecting the points but my computer has been selecting those points for 24hr now.
Is there anyway to not have these points appear in the file when it is imported. Due to the quantity its unlikely that I can change a setting after the file is imported.
HughesTooling
Can you share the DXF file? The points might be arc centres. Fusion's really not suited to working with DXF\SVG files with thousands of lines\arcs so you might not be able to work with your file in Fusion.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Another option is just uncheck points on the sketch palette so they're not visible.
Mark Hughes
