Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
DXF Error
2 REPLIES 2
crDQW6F
301 Views, 2 Replies
DXF Error
Exporting a sketch as a DXF results in errors. When importing this DXF file, I will find incorrect dimensions and geometry that differs from the original sketch. The sketch is completely defined.
Is there a mistake or what can I do?
2 REPLIES 2
patilsm
in reply to: crDQW6F
Hi @crDQW6F,
Thanks for your post.
I tried your workflow for save sketch as DXF and then import again, where you found some incorrect dismension
But I don't observe any incorrect dimension while importing.
If you have any screen cast please attached, so it will easy to understand issue and resolve it easily.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
crDQW6F
in reply to: patilsm
Hi Sagar,
thank you for your answer. I wanted to record the screencast, but last night the DXF export worked correctly. Also this morning it worked correctly. I do not know why the error sometimes occurs and sometimes not.
As soon as the error recurs, I will record the screencast.
Thank you for your help!
Cliff
