Exporting a sketch as a DXF results in errors. When importing this DXF file, I will find incorrect dimensions and geometry that differs from the original sketch. The sketch is completely defined.
Is there a mistake or what can I do?
Thank you!
Hi @crDQW6F,
Thanks for your post.
I tried your workflow for save sketch as DXF and then import again, where you found some incorrect dismension
But I don't observe any incorrect dimension while importing.
If you have any screen cast please attached, so it will easy to understand issue and resolve it easily.
Sagar
Hi Sagar,
thank you for your answer. I wanted to record the screencast, but last night the DXF export worked correctly. Also this morning it worked correctly. I do not know why the error sometimes occurs and sometimes not.
As soon as the error recurs, I will record the screencast.
Thank you for your help!
Cliff
