DWG Won't Open
DWG Won't Open
maple15207
Message 1 of 10
DWG Won't Open
maple15207
I have a DWG file I have uploaded, but there seems to be no way to open it. Any ideas?
Thanks.
Replies (9)
Message 2 of 10
jhackney1972
Please attach the DWG again, it does not seem like it made it to your post.
John Hackney, Retired
Message 3 of 10
maple15207
Upload stalls. Here's a link to it.
https://limewire.com/d/2ACRs#Vwje1od6rc
Message 4 of 10
jhackney1972
I am sorry to say, that site does not allow download unless I create an account, which I am not going to do.  You will need to find another way.
Message 5 of 10
maple15207
Ok. Hope this 1 works.
https://filebin.net/v0xlaa77sdni9co4
Message 6 of 10
jhackney1972
I washed the file through AutoCAD 2025 and received the message attached.  I went ahead and opened it and save as a different name.  I then tried to upload it to the Fusion Data Panel but it failed.  I have nothing else to try.  Sorry.
Message 7 of 10
TheCADWhisperer
@maple15207
Do you have access to AutoCAD?
If you run the List command (LI) on the objects - what does AutoCAD report as the object types? (SOLIDS?).
Message 8 of 10
maple15207
I don't, tho there's a free trial.
Message 9 of 10
maple15207
So the issue you are having is the file itself is un-usable?
Message 10 of 10
johnsonshiue
Hi! The 3rd-party dwg file is corrupted. I am able to use AutoCAD RECOVER command to salvage the file (see attached file). The geometry is extremely big and far away from the origin. I don't believe you can reuse the geometry for Fusion modeling purpose. I suggest you scale down the geometry and confine it within a box of +-100 meter in each X, Y, and Z direction.
Many thanks!
Software Test Engineer
