DWG import into F360 and wrong dimensions
Hi there,
i have looked at all the threads and i can't seem to find the solution to the problem. i'm trying to import a drawing .dwg file and its 10 times as big as it supposed to be. i'm attaching one of the drawing. also i cant select the lines for some reason and i cant turn it into a solid model. if anyone has an input its appreciated.
davebYYPCU
White dots on the outline, shows where the gap is.  Both endpoints need joining on the top of the A plate, and this one here.Opnsketh2.PNGOpnskethc.PNG
Finding them with crossing temporary lines is one way.
Source program is not telling fusion what size it is.  MM > CMetres
How can i scale down the drawing?
TheCADWhisperer
The units of the original file are Inches, not mm.
Ask the source to run the -dwgunits command (with preceding - sign) and change to option  #3. mm.
Can you be little more specific. This is all new new to me so I'm trying to
figure out the lingo. Is there a way I can change the measurements?
davebYYPCU
You said it is 10 times too big,
select all the sketch articles, but not the anchor point to make the change, usually the sketch Origin.
Sketch > Scale, Select the articles, then select the anchor, type in, 0.1, and OK.
Might help....
