Duplicate component then add feature to just 1
john
john
Hi, I'm wanting to create 2 components that are identical apart from 1 hole which is in a different position on each part. I want to be able to modify 1 component and the other to be updated the same - apart from the additional holes.
Is this possible? I've tried creating the component and then duplicating which works fine but can't see a way to then add a hole to each independently - I was hoping that features added after the duplicate was created would not be replicated.
Is there another approach I should use? Any help appreciated.
John
TrippyLighting
I answered that question in this thread. While it did not fit the needs of that user due to the complexity of his components, it will fit yours.
See if you can make sense of the conversation.
john
Thanks - what good timing that was - it works just fine 👍
