drive a jointed assembly in Animation module?
I am trying to find the easiest way to export an animation of an assembly that has mutiple joint connected links.  From the model module I choose the Animate Model and select the input joint and the animated result is exactly what I want to export as a video.  I tried to drive the joints in Animation module but it doesn't seem to honor the joints, should yo ube able to drive the assembly in Animation?  If not, what is the simpest easiest way to export the model animation?
Phil.E
At this time you will have to record the Joint motion outside the Animation environment using a 3rd party video capture tool.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
