Drill along point on line
Hey,
I used the line and point feature to draw the grid i want to cut 12mm holes into . Whenever I try to use hole and select the 'Use Points' it says it cant find a body to drill?
How do i drill at the points in the file I have attached
davebYYPCU
Component Activate - the board you want to drill, (The other will follow suit)
Set Diameter and depth, then select all the points, making sure the preview shows Cut in red.
A 6 x 4 Pattern these 2 holes and supress the excess, doesn't work for you?
Might help....
etfrench
How you select the points is important:
ETFrench
