Drawings - Control of Hatching for Sectional Views
kevinwatts
Message 1 of 8
kevinwatts
In Fusion 360, has anyone found a way to Control of Hatching for Sectional Views?
I believe that this has been on the roadmap for a while. Turning it Off/On and individual control of the hatching lines (thickness, spacing,...) and the pattern is important. Drawings are all about conveying visual information clearly.
At this point the only option I can see, is to save as a DWG file and open it in AutoCAD. Then in AutoCAD delete the "Hatching" layer and recreate proper hatching of the cross sections where and how I want it to be applied.
Kevin
Replies (7)
Message 2 of 8
kevinwatts
I found the answer: Edit the hatch of a section view
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-4BF1BB86-3959-430C-97CB-8E40FA51DA6D
Kevin
Message 3 of 8
terry_fusion
It appears that 3 years later we still have to deal with hatching we don't want.
Why is there no way to at least turn it off?
So frustrating,
Message 4 of 8
jhackney1972
The video will show you a possible workaround to removing a drawing section hatch pattern.  Please pay attention to the warning about retrieving the hatch if you do it.
John Hackney, Retired
Message 5 of 8
terry_fusion
Thank you for the tip.
I believe I'm up to a dozen+  workarounds now for all the things that can't be done normally.
How can this be considered usable?
I sure hope someday this product matures to the point its actually user friendly and functional to a base level.
A very frustrated user.
Message 6 of 8
jhackney1972
Please do not shoot me, just trying to help.  I do not think any application has ever been created that satisfied everyone's needs.  I feel it is always important to be as resourceful as need to get the results you need so I would keep your list of workarounds and use them when needeed.
Message 7 of 8
conor_morganCVP9K
Observer
Observer
I used this work around, thinking that I would never need to get the hatching back.. Of course, as I should've expected, I needed it back at a later date. Not wanting to recast the view and re-dimension the whole thing again, I found a way of bringing the hatching back:
- Double click the section view to bring up the dialog box
- Untick and re-tick the body in the 'Objects to cut' part of the menu
- Hatching is back - I hope this helps anyone else with the same issue
Message 8 of 8
CGBenner
@conor_morganCVP9K
Welcome to the forum  and thank you for sharing what worked for you!
Chris Benner
