Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Drawing tangents to circles
8 REPLIES 8
Message 1 of 9
3957 Views, 8 Replies
Hi
I am trying to draw two lines that are tangent with a circle (in sketch mode obviously) with a fixe angle between the lines.
While it is clear how to enforce tangency of thw lines with the circle, it is not so evident to em how to enforce also the fix angle between the lines.
Thanks for any help.
Cheers
Francesco
8 REPLIES 8
Message 2 of 9
Phil.E
The sketch dimension command will add an angle dimension to the pair of lines.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 9
in reply to: Phil.E
Yes that i now, but i need the lines to be TANGENT to a circle.
In any case I have solved by using the circle command with 2 tangents.
w: Francesco Pessolano
e: francesco@fralke.com
wb: fralke.com
w=who // e=email // wb=website
Message 4 of 9
Phil.E
Francesco,
I want to be sure I understand your question. Is your situation different than the image below? This shows how dimensions and constraints can work together in sketches.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 9
in reply to: Phil.E
yes it does, but your gui looks very different from mine
Message 6 of 9
Phil.E
Can you post an image of your GUI?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 9
in reply to: Phil.E
Actually i think yours is just customised to display more commands on the toolbar ... how does it work?
Message 8 of 9
Phil.E
To add and remove tools from the toolbar: use the little "arrow" or X button that appears next to the tools when you are using the dropdown menu.
(another way to remove tools from the main toolbar is to drag them off)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
Phil.E
in reply to: Phil.E
Removing tools from the toolbar:
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
