Drawing section view hatching extends beyond body lines
harryreslan67
harryreslan67
Hi, please see the attached. The section view hatching extends beyond the body lines of the model drawing.
I'm not too sure what's going on - maybe I have an "open" body, or something is misaligned?
If anyone has experienced this before, I'd greatly appreciate the help.
harryreslan67
Okay,
I half fixed it.
I panned over the hatching - most of it is unelectable but I found a point that was attached to a body. I removed the "problem" body and replaced with an identical one.
Seems fine now - still not sure why it happened. Maybe just a glitch, but it was present after rebooting.
ClintBrown3D
Hi @harryreslan67
I’m sorry to hear that you are having trouble. I'm glad that you managed to find the issue with that body.
If you run into this again, I can ask the team to take a closer look for you. Please share a downloadable link to your drawing, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
harryreslan67
Happened a couple more times - seems to be when taking a section view through a shelled component. Unfortunately, that's exactly what I need to do.
Still not sure why it's happening...
harryreslan67
Hi Clint,
Please see the below:
https://a360.co/4cVUzLx
It seems very repeatable, it's happening every time I try to take a section view, even if the body/component has been replaced and it's a new function.
liang_chen
Hi @harryreslan67 ,
In the 3D design, Base Buildup and Component32 components are overlapped, and the overlapped areas are quite tiny, which leads to the issue in drawing section view. Showing as attached video, hiding either of them will result in the correct section view.  So I assume the issue is caused by the modeling issue, and please try to resolve the overlapped components, then check if it helps.   Thanks
(view in My Videos)
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
