Drawing Query
Drawing Query
AntR32Bool
Drawing Query
AntR32Bool
Hi
I wonder if I could get some feedback on my design/Drawing please.  This drawing was taken from a design of mine as a front door assembly for a 3D printer. the question lies about the hole dimensions & specifically how I've marked them up & whether or not I've done that correctly, I'll explain what I wanted & then what I had in return.
As I didn't have the recourses to cut this myself I sent it to a perspex cutting business etc etc. the 8 holes around the door frame & the 4 holes in the door were meant to be'  a 4.5mm hole with a 8mm countersink at 90'..what I received was all holes drilled out to 8mm. & now I'm a little stuck as what todo.  I could easily 3D print some inserts to make them the correct size again but that would mean changing other parts which were designed & printed beforehand. & if I'm to blame then thats what ill have todo I guess. whereas if it was a mistake on their part I'm sure they won't mind rectifying their mistake "hopefully "
cmiller66
Hi Anthony.
From what I see, you clearly have the countersinks called out:
And a quick Google image search of ISO countersink dimensions brings up a bunch of dimensions that look just like yours.  Provided this is the drawing you sent them, I'd take it back and show them the c'sink symbol.
Chris
AntR32Bool
hi Chris
Thanks for taking the time to double check this for me. I'd looked online myself whilst marking it up initially & again when the door arrived & everywhere I looked inc some posts I'd read showed all countersunk holes marked up just like mine. & I did email them but as its a BH weekend I'm sure I'll not get a reply until next week now. so I guess I'll see what happens.
thanks again
Anthony
