Drawing Overall Dimensioning of Soft Edge Component
3 REPLIES 3
John_C_Hansen
171 Views, 3 Replies
While creating a drawing of the top, I am trying to get an overall dimension of the width. Without any hard corners, I am unsure how to begin. I am trying to communicate that this can be cut from a single 4ftx8ft sheet of material.
Would it help to upload the design file?
3 REPLIES 3
I wish you had attached your model so I could have used it.  I made a very crude model to show you how to use Edge Extension in your drawing.  Video attached. You can also, after starting a drawing dimension, right click and get a host of snap keypoints that maybe will  help you.  Hope it gives you an idea.
John Hackney, Retired
Does my post help you to solve your issue?
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
I modeled a rectangle as if it were on the floor under the desk. I applied a clear Glass appearance to it and this is the Drawing that I then dimensioned similarly to the original with the added dimension of the 48x96 inch.
