Drawing from animation not coming in exploded
nade2575
Observer Observer
nade2575
Observer
Observer
I was trying to do an exploded view drawing from animation but when I went to drawing, from animation, it was not coming in exploded. I tried redoing the animation, signing out, creating a new storyboard but none of it worked.
CGBenner
@nade2575 Welcome to the forum!  Thank you for sharing your question and your file for the experts to look at.  Good luck!
Chris Benner
-KyleWilliams-
Hey @nade2575
Sorry to hear that you are facing this issue.
We've had this reported a few times for exported designs with configurations. We have the fix ready and should be available by end of this month.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
Ivan-Gourlay
I am currently suffering the same problem. I was able to use Fusion to create drawings of exploded views and then today it stopped working. The link to "solution" is just your post but nothing else. Can you please direct me to the solution?
ben_gBU3HY
Any update on when this bug will be fixed?
I am currently experiencing the exact same issue. Trying to add a story board with an exploded view to a new sheet on an existing drawing (with everything selected correctly) and I get the base view from design mode (unexploded) instead. I've tried all kinds of stuff. Verified that this is the case in the drawing, the storyboard is not in the browser at all, only the component list from the models design mode.
The problem seems to develop once I create a second storyboard if that matters.
