Why is this dimension red?
etfrench
Mentor Mentor
etfrench
There are no warning or error messages.  Changing one of the driving dimensions will turn it black.
ETFrench
ltomuta
What is the expression of that dimension?
etfrench
It just equals the driving dimension above it.
ETFrench
ltomuta
Indeed, I downloaded your design and saw it. But the dimension is not red
in it while all the values seem to be the same. So it seems to be something
else that bad math in an expression as I was initially suspecting.
davebYYPCU
The inner circle is driving dimension?  Looks like a driven.
More likely a tolerance thing where the fifth dimension in the chain, breaks its calculator.
Might help….
etfrench
Adding the driven dimension of the inner circle turned the offset dimension red.  Adding a driven dimension to other circles will also turn their original locking dimensions red.
ETFrench
