drawing file
drawing file
Message 1 of 8
drawing file
I am trying to create a drawing from model and after unchecking full assembly it still includes the whole assembly , is there something to do other than what is in the instructions ?
Replies (7)
Message 2 of 8
NicolasXu
Hi gregore1,
I tried to create a drawing from an assembly, but not able to reproduce the problem. Please refer to the gif below for my steps. Could you check if it's still reproducible on your side? If so, would you provide more information (screencast, screenshot, etc.) so we can take a further look at it?
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 8
instructions for screen casting where clear enough but then there is no instructions on how to get the video to this section
Message 4 of 8
<iframe width="640" height="590" src="https://screencast.autodesk.com/Embed/Timeline/b370d387-2849-4ecd-9d55-ebac47a8211a" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
Message 5 of 8
NicolasXu
Hi Gregore,
Thanks for the screencast. From the video, it looks like all the visible objects are bodies under the root assembly.
In the Create Drawing dialog, we’re going to select “components” to be included in the drawing, so if you click on a body, the corresponding component which the body belongs to will be counted into the selection. In this case, the root component will be added into the selection.
So for your case, you may create components from the bodies first then create drawing by selecting components.
Here is a page to explain the difference between bodies and components:
http://fusion360.autodesk.com/learning/learning.html?caaskey=caas/CloudHelp/cloudhelp/ENU/Fusion-Fun...
Here is a post for how to embed a Screencast video in a forum post – after 0:40” (The UI of screencast had changed, but the embed workflow is the same.)
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/how-to-embed-a-screencast-video-in-a-foru...
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
Message 6 of 8
I would like a drawing of just the visible base (body object) I want no components in the drawing as I have already purchased them and am now designing the granite base for them to sit on.
Message 7 of 8
HughesTooling
The problem is you can only make drawing of the whole design or components. I think your body is in the top component that contains the whole design so when you pick that body you end up selecting the whole design. What you'll have to do is right click on the bodies and select Create components from Bodies. Then you can pick the individual components when you want to make a drawing.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
this workked thanks
