Drawing environment direction wrong when Z up
vaino_komulainen_ax
vaino_komulainen_ax
I noticed that when Z is up direction in part, in drawing editor the environment lighting is wrong. Environment top is from the back.
If Y is up direction in part, then drawing environment lighting direction is correct and light comes from top.
whittakerdw
Can you share a screenshot and an .f3d file of your model?
vaino_komulainen_ax
Yes, of course. Here is the 3D model and drawing files with the Y axis pointing up.
I'll post the Z axis files in next post.
vaino_komulainen_ax
Z axis up
whittakerdw
The issue is lying with the placement of the part from the origin. When you flip the view of the view cube, you have to use "Top" according to the origin (circled in red). What you were using is the top of the model which was really the side because the view cube had been moved
