- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Can't dimension the radius of the bended antenna or set centermarks.
WHY?
The 3D and the drawing file is attached.
WHY?
You really won't be able to dimension that because the bend makes the arc not planer to your view.
The best solution would be to cut a section through the middle and dimension the arc on the section:
